03-20-2009, 06:40 PM   #1 (permalink)
2007 GT/CS
3:55 to 3:73 Gear Change Help Needed
Could use some instructions to remove and replace C clips to remove axle shafts. Is there any program changes required when changing from 3:55 to 3:73? Any help would be appreciated. Thanks
2007 GT/CS is offline   Reply With Quote
03-20-2009, 06:51 PM   #2 (permalink)
bassman97
Re: 3:55 to 3:73 Gear Change Help Needed
Unbolt and remove the calipers and brackets, remove the ABS sensors, unbolt the diff cover and drain the fluid, take out the cross shaft bolt on the diff (it's a very tiny bolt the goes through the cross shaft), remove the cross shaft, and then push each axle in one at a time, while using a magnet to remove the c-clip. Then the axles should come out nice and easy. As for the gear swap, you need to reprogram the computer so that the speedo is accurate.
tire change or gear change elsanyo All Ford Techboard 18 08-20-2008 07:58 PM
gear change up or down elsanyo All Ford Techboard 2 04-05-2008 06:21 PM
Can u change 5th gear? Fordota All Ford Techboard 7 05-08-2007 08:03 AM
Gear change SweetStang All Ford Techboard 2 04-11-2007 09:55 AM
Distributor gear change? mikes82GT All Ford Techboard 11 04-16-2003 10:05 PM
