08-29-2007, 10:24 PM   #1 (permalink)
Ranchero65
Ranchero Sub frame connectors.
For those that have uni body Rancheros you can stiffen up the chassis and stop body twist. Sub Frame connectors is a good way to do it . Thee are several places that make the connectors and are ether bolt on or weld on . I my self prefer the weld on connectors because there is no worry about the bolts coming loose or breaking . Below are some pic's of the connectors I bought and then decided to make my own .
The pic below is sub frame connectors bought from Dearborn Classics I didn't like them at all .
This pic is the ones I made out of 1.5 X 2" tubing 3/16th thick.
Here's what they looked like on the Ranchero
All painted up .
Take Care
Earl - Ranchero_65 Restomod Slowley in Process !
www.ranchero65.com
Ranchero65 is online now   Reply With Quote
08-29-2007, 11:38 PM   #2 (permalink)
gotyurback
Re: Ranchero Sub frame connectors.
It look very, very nice.
1969 Ranchero 500 351W
1963 1/2 Galaxie 500 XL 390FE
1964 Comet Caliente 347 EFI
1967 Mustang 289
gotyurback is offline   Reply With Quote
09-16-2007, 09:08 AM   #3 (permalink)
ray55classic
nice work, it's good to see fabrication done at home. i do my own fab work also, i recently had built rectangular tubing upper and lower rear suspension control arms on my 79'gt "baby" that was totaled out last month.........ray
ray55classic is offline   Reply With Quote
09-16-2007, 11:20 PM   #4 (permalink)
Ranchero65
Hi Ray , Welcome to FM and to the Ranchero section ! To me working on older vehicles I know you can't always find the parts you need so home fabrication is all thats available . Luckily for me I have a good friend and neighbor that if I can't figure it out he can and if I don't have a certain tool he does and vise versa .
Take Care
www.ranchero65.com
09-17-2007, 03:59 AM   #5 (permalink)
canoe
I like the way you made those to conform to the existing support. Nice work!!! Do you have plans for any sway bar additions for the back axle?
canoe is offline   Reply With Quote
09-17-2007, 06:08 PM   #6 (permalink)
Ranchero65
Yes I am planning on a sway bar for the back I already have 1 1/8 " for the front . I have read on several places that the Mustang sway bar will work but it's about the last thing on my to do list.
Take Care
www.ranchero65.com
09-17-2007, 07:05 PM   #7 (permalink)
trikar
Beatuiful job there Earl!
trikar is offline   Reply With Quote
09-17-2007, 07:43 PM   #8 (permalink)
canoe
I put one in my '73 Mach 1 and it makes a ton of difference to how it handles. That kit I got from NPD about 20 years ago, the only thing I haven't been happy with is the arrangement to attaching the sway bar to the spring is a little weak and was prone to failure. I repaired it once and after it broke a second time I beefed up the arrangement with sturdier stock and haven't had a problem with it since. In case that might be helpful...
Sub frame connectors kechke Mustang Pages (1965-1973) 2 04-13-2006 01:38 PM
Frame connectors help. BobsSleeper Late Model EFI Techboard 4 09-26-2004 09:44 PM
Frame connectors help. BobsSleeper All Ford Techboard 1 09-24-2004 09:40 AM
frame connectors torino420 Fairlane Pages 1 05-04-2003 10:28 AM
sub frame connectors FAIRMONT All Ford Techboard 2 10-26-2002 05:27 PM
