Re: Leaf Spring Question
Thought I'd share my bolt removal experience with you. (1) Pre hose'm with WD or something like it. (2) Bust the nut off best you can. (3) If the bolt is rusted in position, get a large C clamp, a 5/8th(?) shallow socket and most importantly, at least a half rack o cold ones, becase this may take a while. Put the socket over the bolt head, and the C clamp on the socket and nutless bolt end, a crank it down, a little more WD, beer yourself, repeat. You may only get a 1/4 turn on the clamp per attempt, but that's fine. It may take more than a day, but you will eventually win. One caveat though and this is big; you may run out of beer. Shoot for the whole case.
