02-04-2008, 07:43 PM   #1 (permalink)
bvgeh
1960 Falcon Ranchero V8 suspension?
I have a 1960 Ford Falcon Ranchero. I plan to swap out the 200 inline 6 for a V8. I was wondering what suspension to use for a V8?
bvgeh is offline   Reply With Quote
02-05-2008, 09:03 AM   #2 (permalink)
lees6t
Re: 1960 Falcon Ranchero V8 suspension?
BV
Maybe this can give you some ideas. I have a '60 sedan with a 302/AOD, so the front suspension is probably the same. I used upper and lower control arms for a 64-65 Mustang
with Granada spindles and disc brakes. These parts are a bolt-on. The control arms can be gotten from any Mustang vendor at a reasonable cost. The brakes are another story but
the parts are still out there. In fact there is a vendor marketing complete Granada conversion parts (I'm at work and don't have the info at hand but can post it later today).
For steering, I initially used the original stuff with bushings from Mustangsteve to adapt the 6cyl. tierod ends to the Granada spindles, but later switched to rack and pinion, with a unit from Randalls Racks, again a Mustang piece ,that was easily modified to fit. Don't know what you have for engine mounts, but Ron Morris adjustable mounts (another Mustang component) work well. I use them and they allow a more comfortable fit of the engine placement/headers/trans etc. For the rear, I'm using a composite monoleaf spring instead of the usual steel leafs, with a Currie modified 8" rear end. 8" rears from the mid '70s Mavericks and Comets are a good fit, but check your wheel backspacing and fender clearance
Lee
'60Falcon 302/AOD
"54 Ford sedan 351W/c4
lees6t is offline   Reply With Quote
11-01-2008, 02:32 PM   #3 (permalink)
bvgeh
Post Re: 1960 Falcon Ranchero V8 suspension?
What coils springs should I use with the mustang Control arms
11-01-2008, 09:40 PM   #4 (permalink)
the weight is only 60 lbs diffrent between the two motor's, so original springs ingood condition will be fine if you're keeping the suspension stock.
11-11-2008, 07:40 AM   #5 (permalink)
coosbaylumber
Nawww...
I disagree. The original Falcons were sort of low to the ground. Any weight increase would then just make it lower yet. Especially if there are the original rubber ended upper bushings. The 1961 changed all that in going to solid upper ends.
I think the spring rate needs to be bumped up a notch or two.
Wm.
Old Ford owner
Selling 1960 Ranchero fassteddy Vehicles for Sale 0 12-18-2007 04:32 PM
1960 Ranchero coosbaylumber Ranchero Pages 7 11-12-2007 08:23 PM
1960 Galaxie - Ranchero? crazygutgut Galaxie Pages 14 12-07-2006 10:23 AM
5.0 suspension brakes tranny etc. to \'65 falcon ranchero amadorjon All Ford Techboard 0 03-20-2005 12:42 AM
1960 Falcon Ranchero Wheel Falcon Pages 18 08-13-2004 09:19 AM
