Go Back   FordMuscle.com Forums > Premier Forums > Tech Exchange > Rear End Articles
07-14-2008, 10:46 PM   #1 (permalink)
F15Falcon
Crush 9" Crush Sleeves Easily:
If you have ever built a 9" Ford third member, the hardest part is getting the crush sleeve crushed to allow the proper pre-load on the pinion bearings. You need a really hard hitting impact wrench with a really big compressor to get it done, and most of us don't have that luxury at home. This is my solution:
I built a simple fixture that would hold the pinion,bearings, crush sleeve, bearing retainer and yoke together as an assembly so that I could tighten the pinion nut and crush the sleeve for proper pre-load.
The fixture is a simple piece of heavy 3/8" thick angle iron that is drilled to allow the yoke to bolt to it, there is also a hole bored in it that will allow a socket to tighten the pinion nut. Mine is bolted to an "I" beam that I use to straighten out rearend housings. The "I" beam is bolted to the side of my old Bradford lathe. Whatever you bolt it to, it has to be very sturdy as it has to take some abuse.
A trip to a local swap meet turned up a heavy duty 1 1/16" 3/4" drive socket and a socket adapter. The heavy duty socket is needed as 1/2" drive sockets and breaker bars will usually shatter, ask me how I know. The socket adapter had a 7/8" hole in it. A trip to a boneyard turned up a 7/8" torsion bar which I cut to 36" in length. The torsion bar will be the lever that turns the socket, it is hardened, and it will not break or bend.
The whole pinion assembly is bolted to the fixture, and the pinion nut it tightened until the proper pre-load is acheived. I use my body weight to slowly push the torsion bar and the sleeve is crushed with ease. The 36" length easily allows the sleeve to crush. No more broken sockets, breaker bars or bench mounted vices!!
07-15-2008, 12:40 AM   #2 (permalink)
Re: Crush 9" Crush Sleeves Easily:
I had a very similar tool a long time ago... Bolted it up and swung it up to teh undercarriage or frame somewhere tehn went to town...
Only used it once and was told I got the pre-load too tight... so I stopped doing it
Honor!
07-15-2008, 05:30 AM   #3 (permalink)
My427stang
That works!
I usually pre-crush them a little before assembly, but thats even better, because once you get them moving you can keep going
Good idea
70 Sportsroof, 427 FE/489 cid, TKO-600, 3.70, A/C. Currently undergoing full MAF port EFI conversion with CnC ported Victor/1200 cfm throttle body. Stay tuned!!!
07-15-2008, 06:41 AM   #4 (permalink)
blykins
...or use a solid spacer.
Ross is right though....slick idea.
blykins is offline   Reply With Quote
07-17-2008, 09:00 PM   #5 (permalink)
iwantmore
Solid spacer is the way to go. Assemble and disassemble with no problem. It is also stronger
07-18-2008, 12:07 PM   #6 (permalink)
cweagle
With the spacer (aka "crush sleeve eliminator") you still need to crush an actual sleeve first, using the standard procedure. Then you remove it, measure it with a micrometer (very carefully!) and reinstall the eliminator along with the correct, precision, shim(s). The eliminator just keeps the sleeve from crushing any more under severe operation.
cweagle is offline   Reply With Quote
07-18-2008, 04:36 PM   #7 (permalink)
allenman85
No not really. There is a very clear selection process described in the Ford procedure. You start with a reference spacer and torque. Once torqued, you measure play and select the correct thickness spacer and you're done.
A Ford pro told me that Ford eliminated solids on the assy line years ago in favor of the crush sleeve so that's all I use now.
1970 Cougar, 3660 lbs
418W, C6, 3.50 posi, slicks & street trim
Best 1/4 mi: 11.24 @ 119 MPH Best 1/8 mi: 7.13 @ 96.32MPH
07-18-2008, 05:55 PM   #8 (permalink)
F15Falcon
I've always used the crush bearings, and I have never had them loosen up, even on my circle track car after several hundred laps. As a matter of fact, I have bought several complete third members from Nascar teams, and they have all had crush bearings in them.
07-18-2008, 09:50 PM   #9 (permalink)
My427stang
I prefer the spacer too, but also have never had a crush tube fail.
I like the spacer mostly because if the seal leaks, you can just zonk it back down with an impact, without pulling the pinion housing out.
Other than that, never a failure with a crush tube, even launching a 399 FE with a Predator carb on nitrous with my truck on a truck pull in the old days
03-14-2009, 08:15 AM   #10 (permalink)
FATNFAST
Tom,
I just had to move this to Tech Exchange. Thanks.
Rick in Indy "408 Clevor" 9.64@137 1.30 60ft
HTML code is On
9" Crush Sleeve Torinoguy23 All Ford Techboard 12 03-27-2008 11:46 AM
Ford 9\" crush washer allenman85 All Ford Techboard 9 04-04-2006 09:38 PM
ZRX61 has a Galaxie he wants to sell or he is going to crush it. dpfalls The Garage 42 02-02-2006 08:57 AM
Gonna crush the \'69 Monterey, what should I keep? ZRX61 All Ford Techboard 6 06-10-2003 03:10 PM
Bearing "crush" SteeLDawN All Ford Techboard 4 09-15-2002 12:10 AM
