Go Back   FordMuscle.com Forums > Premier Forums > Tech Exchange > Rear End Articles
03-31-2009, 06:28 PM   #1 (permalink)
F15Falcon
Fixing 9" Ford Pinion Leaks:
Nothing is more annoying than a nasty oil spot on your clean driveway or garage floor. In this case a newly rebuilt 9" centersection in our project Bronco started seeping oil almost as soon as it was filled with oil.
Here is the annoying spot on the shop floor:
A little investigating led me to determine the oil was leaking out of the pinion or seal area:
I started the process by removing the pinion nut using my 18 volt Craftsman cordless impact wrench. If you have never used a cordless impact wrench, you are missing out because I cannot live without mine:
I had replaced the pinion seal, but I re-used the pinion yoke even though there were a few small grooves in it. It was most likely the culprit. A call to Randy's Ring & Pinion got me a new yoke, pinion seal, and pinion nut. There are repair sleeves for the yokes, but they are only $5.00 cheaper than a whole new yoke, which cost me about $50.00:
I cleaned the splines on the pinion with some brake cleaner to remove any remaining oil:
I next smeared some silicone on the inside of the yoke as I have seen the yokes leak through the splines:
I did the same on the pinion nut:
Some bearing grease was smeared on the sealing surface of the yoke to keep the seal from burning up from being dry:
I didn't replace the pinion seal because it had just been replaced, and the vehicle did not run at all. I placed the yoke back on the pinion and seated it as far as it would go by pushing on it:
The pinion nut was then replaced and threaded on by hand:
There are different ways of making sure that the pinion bearing has the correct amount of pre-load such as counting threads, or turns of the pinion nut. I have a different method: While tightening the pinion nut with the impact wrench, I pull on the yoke to see if there is any play on the assembly. I slowly keep tightening the nut until a slight amount of resistance is felt, and then I go 1/16th of a turn more which is the correct amount of pre-load on the pinion bearing. The cordless impact WILL NOT crush the crush sleeve any further than it is. I have used this method on dozens and dozens of 9" centersections and I have never had one fail yet:
The best part of the whole process is the clean floor.
04-01-2009, 04:02 AM   #2 (permalink)
dennis111
Re: Fixing 9" Ford Pinion Leaks:
I've successfully used this method many times too with no ill effects (although most recommend not to do it without a new crush sleeve.) Glad that you mentioned the silicone on the splines as I found that to be a problem also.
Now when I rebuild a 9", I use shim washers instead of the crush sleeve and really don't need to worry about crush when doing the above repair.
Dennis
11.21@124.0 al naturale
My Racing Videos
04-01-2009, 06:55 PM   #3 (permalink)
Gydyup
Great, thanks! Didnt know you could do this without pulling the pinion and replacing the crush sleeve.
Mine was leaking through the pinion nut I thought, must have been the splines. Needed rebuilding anyway, hope it doesnt leak now, but if it does I can fix it.
Gydyup - 67 Mustang Coupe
"old School"
04-01-2009, 07:51 PM   #4 (permalink)
galaxie
Very cool!
59,60,64,65,66 Galaxies Y-blocks to FE Strokers
87, 93 Mustangs Stock & 331
Pittsburgh PA
http://threerivers.galaxieclub.com/
galaxie is offline   Reply With Quote
HTML code is On
1967 Ford Fairlane " 427 " Calspec The Garage 12 09-11-2008 07:48 PM
Roush "Ford-in-a-Ford" powertrain package ShotRod64 Galaxie Pages 10 07-17-2008 09:34 AM
1973 Ford Gran Torino Sport "Q" code jjj2007 Torino Pages 6 01-28-2008 08:19 PM
"The Mighty" 1963 Ford Falcon at Pueblo FATNFAST FM Video 8 12-17-2007 12:29 AM
"Victory by Design" on Speed, Ford Muscle series ga289stocker The Garage 0 07-08-2007 10:35 AM
