Go Back   FordMuscle.com Forums > Model Specific Forums > Street Rod Forum
09-14-2007, 09:58 PM   #1 (permalink)
F15Falcon
'27 Track T Paint and Assembly pics:
This is a 1927 Ford Track T that I started building in February. It will utilize a Speedway motors fiberglass body. It will be powered by a 302 Ford engine backed by a Toploader 3 speed and an 8" Ford rear end. The chassis is basically mild steel rectangular and round tubing that I built. The front end will have a "suicide" spring perch with a 1937 Ford "I" beam axle, 1939 Ford spindles, Model "A" split wishbone, and 1956 F-100 drum brakes. I hope to have the car running in a few weeks.
I blasted the chassis, and my dad did the honors of spraying the Ford Blue urethane.
09-15-2007, 12:18 AM   #2 (permalink)
Ranchero65
Thumbs up Re: '27 Track T Paint and Assembly pics:
Hey man that looks like a nice start . Please keep us updated .
Take Care
Earl - Ranchero_65 Restomod Slowley in Process !
www.ranchero65.com
Ranchero65 is offline   Reply With Quote
09-15-2007, 05:41 AM   #3 (permalink)
rancheroo
Awsome Tom...
rancheroo is offline   Reply With Quote
09-15-2007, 01:05 PM   #4 (permalink)
ixtlan
Looking good Tom, keep us posted.
RatStang Restoration
Restoration, Paint, Body, Light Fabrication.
www.RatStangRestoration.com
09-15-2007, 04:07 PM   #5 (permalink)
CaptVirgilHilts
Saw it on the HAMB! Looks great. Nice to see blue, as red has been done to death. Love the lightening holes on the back plates!
Stu
1967 Mustang Coupe
09-16-2007, 09:57 PM   #6 (permalink)
F15Falcon
Got the rear end installed. It's an 8" out of a '75 Maverick with 2.79's. I also managed to install the brake lines, adjust the brakes and fill the rear with oil.
The Dodge Dart steering box, Howe clutch M/C, and '68 Mustang M/C are all installed. I also installed the clutch and brake pedals.
The radiator and nose mount is installed. The radiator is a '65 Mustang unit. The nose will D'zus in place. The car will sit 3 inches lower than the picture.
The car is now a roller. The rear wheels are mid 70's Chrysler Cordoba's turned around backwards. They look like old Halibrands.
Speaking of wheels, this is the swap meet steering wheel I am going to use.
10-08-2007, 10:07 PM   #7 (permalink)
F15Falcon
Been at it pretty much every day for 3 weeks, here is some of the progress:
The dash is a simple aluminum plate with only the basics.
I used a Ford 40 amp generator because it looked more appropriate.
The headlights are Guides off a White firetruck.
The headers are Schoenfelds that are made for an IMCA modified, but work quite well here. The valve covers are from an '85 Mustang, but they look as traditional as the Corvette covers the Chevy guys use.
The coolant recovery tank is a 12" long piece of 2" copper tubing with a couple of core plugs silver soldered on.
The fuel pump is from a '64 Fairlane with a 260 V-8. It has the integral fuel filter that really simplifies the fuel system.
The distributor is an N.O.S. Mallory dual point bought off the 'Bay for $20.00. The intake is an old Edelbrock F4B, and the carb is an Autolite 2100. Yes the fuel line is copper, and it will be just fine.
10-10-2007, 01:35 AM   #8 (permalink)
jeremyl
Looks awesome!!
At one time I'd planned on building a Track T out of a 1917 body that I had.. then I changed my mind & was gonna build a regular T Bucket but with the engine/transaxle in the bed.. and finally I got rid of it to a friend who will probably get around to it before I would have.
85 Ford F-250 6.9 Diesel
86 Daytona Turbo Z C/S
jeremyl is offline   Reply With Quote
10-20-2007, 02:54 PM   #9 (permalink)
james302
I LOVE this project and you have some incredible ideas that I have never seen before. Please keep us up to date with your progress.
james302 is offline   Reply With Quote
12-03-2007, 09:23 PM   #10 (permalink)
F15Falcon
Got the car running, and I am in the process of finishing it up.Here is some of the latest progress:
The body is back on:
Got the exhaust done:
Model A horn bolted on:
Cal Custom air cleaner scoop installed:
A thermostatically controlled choke doesn't hurt, it works like a charm:
The gas pedal and horn button. The gas pedal "spoon" is a real spoon. All three pedals pivot on the same bolt with nylon bushings.
Most of the interior is installed:
Fuel line and oil pressure lines connect at this bulkhead:
The engine has to have a good ground:
The spring/wishbone connection:
All the brake lines connect at bulkhead fittings:
The tranny crossmember:
The starter is a late model PMGR unit:
Exhaust bracket, I tried to drill as many items as I could:
The panhard bar is adjustable at both ends:
Pitman arm:
Undercarriage:
The Hollywood Wheel Disc 15" x 5" front wheels were painted white:
'27 Track T Paint and Assembly F15Falcon Makin' Progress 15 12-04-2007 05:38 PM
Post your Track Pics admin The Garage 18 06-28-2007 07:09 PM
few pics from last weekend at the track dragracerdave Mustang Pages (1974-1978) 0 05-13-2007 03:40 PM
Paint scheme pics, Opinons? lynched1 The Garage 4 06-02-2005 10:37 PM
Mike545 at the Track Pics (Really!) Bossman The Garage 4 08-01-2003 08:01 PM
