Go Back   FordMuscle.com Forums > Model Specific Forums > Street Rod Forum
01-14-2008, 08:41 AM   #1 (permalink)
fassteddy
8" spool ?
I am trying to ID a Ford Differential Spool. The part Number is C4AZ-4204-E, I cant seem to find the discription in any Ford Info. Any one have any idea's. I would like to find out if this the Posi unit or not . Fasteddy
fassteddy is offline   Reply With Quote
01-19-2008, 11:32 AM   #2 (permalink)
rodbender
Re: 8" spool ?
I'm not suire about the 8 inch but on the 9 inch posis the bolts that hold the unit together are countersunk where as the non posis are flat. Hope this helps
32 five window, 63 Futura conv., 65 2+2-wip, 66 Mustang conv.-what's left of it.,72 'chero GT, 76 Highboy, 94 Mk VIII
rodbender is offline   Reply With Quote
06-25-2008, 10:09 AM   #3 (permalink)
MY TWO STANGS
Re: 8" spool ?
Originally Posted by fassteddy View Post
I am trying to ID a Ford Differential Spool. The part Number is C4AZ-4204-E, I cant seem to find the description in any Ford Info. Any one have any idea's. I would like to find out if this the Posi unit or not . Fasteddy
On all ford posi units if you look into the hole were the Axle goes one side will have two sets of Axle splines and the open diff has one . One set of splines drives the clutch pack the other drives the axle gear.
2004 mustang bullitt 17x8 rims & 1" spacers & 3/8" spacer for sale rmousir Parts for Sale 6 01-15-2008 11:47 AM
1977 LTD II, S-code ["SPORT II" clone project] $1200 MERCURYMUSCLE Vehicles for Sale 1 01-14-2008 04:28 PM
Disc swap prop valve, "T" fitting questions ? lgh1157 All Ford Techboard 3 01-01-2008 10:28 PM
"Victory by Design" on Speed, Ford Muscle series ga289stocker The Garage 0 07-08-2007 09:35 AM
locker, full spool or mini spool? james302 All Ford Techboard 4 09-27-2005 06:43 PM
Lakewood
