Go Back   FordMuscle.com Forums > Model Specific Forums > Street Rod Forum
06-01-2008, 08:04 PM   #1 (permalink)
631/2galaxie
429 questions!!
Look I am new to the whole BIG block thing and I dove in head first. I bought a 63 1/2 fastback with a 429 already sitting up front I will admit I got all big eyed and now I am alittle over my. So here is the deal, I am leaving for my third tour of Iraq this Sept and would nothing more then to here this thing run. I know it is not in great shape nut it spins freely. I was wondering what the best course of action would be a this point. Rebuild or just replace parts and see if it will run any and all help will be great as I just want to drive it once before I park it for another year. O yeah it has a auto and a four barrel card that someone was nice enought to take not long after I got it. But other then that I know not where this engine came from. I just know I LOVE the car. Thanks for all you help Josh
631/2galaxie is offline   Reply With Quote
06-01-2008, 09:09 PM   #2 (permalink)
ford4v429
Re: 429 questions!!
if its been sitting for less than a couple years, I wouldnt be too afraid to fire it up...pop the plugs, if all is dry in there maybe spray some oil in. my neighbors 65 (289) had sat untouched about 2.5 years before I got it- I sprayed some aerosol oil in the plug holes before trying to fire it up, after getting everything tuned up, seems no worse for wear- never noticed any smoke, dont use any oil...will tick like crazy as surely the lifters are going to be bottomed and likely stuck- I put some CD-2 additive in the gal along with fresh oil before starting it, within 15 minutes it was quiet as a churchmouse.
one other thing I did was crank it with the coil wire off until I got oil pressure light to go off...cranking dry at a couple hundred rpm for 30 seconds vs. running a few seconds at 1000 rpm without pressure might be a coin toss, but it just 'felt better' to me to crank it till it had pressure. hooked up the coil, poured some gas in the carb, fired right up for a few seconds...repeated adding gas 3 times before pump filled the carb, then it was on its own ticking away...
some old engines can get rust on the starters too- might suggest pulling the starter lubing the bendix- have heard of them sticking/not releasing the solenoid contacts, not allowing the engine to be shut down...closest to this I ever came was my F150 sticking causing one helluva gear noise as the starter gear stayed engaged probably spinning about a bizillion rpm once the engine started...but something to watch for.
If you like that old Gal already, youre gonna love that 429
Confidence: that feeling you have just before you realize the mess you've gotten yourself into...
http://www.hometown.aol.com/ford4v429/gal1.html
ford4v429 is offline   Reply With Quote
Sorry i still have questions 351sportscoupe Fairlane Pages 21 02-20-2006 02:20 PM
Some questions truedog All Ford Techboard 3 12-22-2005 03:58 PM
\'64 Questions 64RestoMod Falcon Pages 18 12-06-2005 07:21 PM
More cam questions? Please help BLstangin All Ford Techboard 18 02-06-2004 01:31 AM
T5 questions Huskinhano All Ford Techboard 1 06-18-2003 01:02 PM
