Go Back   FordMuscle.com Forums > Model Specific Forums > Street Rod Forum
02-16-2009, 12:57 PM   #1 (permalink)
hotrod101
rackn'pinion steering on '29 front suspention
I have a home built frame with a '29 ford straight axle and buggy spring. I want to install a '95 dodge neon rack 'n pinion steering setup. The old mechanical steering is junk. The r&p lines up with the spindle brackets ok. What do I need to do to accomplish this?
thanks, hotrod101
hotrod101 is offline   Reply With Quote
02-17-2009, 10:21 AM   #2 (permalink)
416Ford
Re: rackn'pinion steering on '29 front suspention
Sound like you want to use parts you have laying around.
If the car is fenderless I myself would not go that route.
Why are you switching to a rack rather then rebuilding the existing parts?
416Ford is offline   Reply With Quote
02-20-2009, 08:37 AM   #3 (permalink)
hotrod101
The car is completely "scratch built" The '29 front end is a "field find". I wanted the early look with an easy controled steering assembly.
02-20-2009, 11:50 AM   #4 (permalink)
416Ford
ote=hotrod101;1474944] I wanted the early look [/quote]
You will not get that with a rack and pinion.
This may drive easy but it is not the classic look.
I don't have one but I always thought they were light up front and the steering was only in need of a better steering box?
Classic suspension:
03-23-2009, 03:14 AM   #5 (permalink)
Fuzzy Knight
thanks, hotrod101
I have done this!
First and formost it has to be mounted to the axel
Second you have to use Borgenson (sp) joints to hook up the steering.
It will work fine but looks like crap.
Fuzzy
Fuzzy Knight is offline   Reply With Quote
05-26-2009, 08:48 AM   #6 (permalink)
hotrod101
Because I am an absolute novice about hotrod building. I am retired now but always wanted a hotrod (cool and different)! What I have is a homemade frame,constructed from 2x4 steel supports(used for holding shipping loads of material in trailers. Also a '57 chevy rear axelhousing mounted in place with coil springs. Also, a 350 chev. transmission mounted to a 305ci chevy motor. The front suspension is a '29 ford model A (I was told). It has no body at all yet. I was told the old mechanical steering was too sloppy to use. A power rack n' pinion would be a nice choice, I was told.
front suspention questions plumber68 Mustang Pages (1965-1973) 3 12-12-2005 01:56 PM
not good for suspention- anyone here tried this? 64Galaxie500 The Garage 8 03-01-2005 07:25 PM
Front suspention?? sixtyeight All Ford Techboard 7 03-22-2004 09:56 PM
Suspention questions kcw12 Galaxie Pages 0 07-19-2003 03:13 AM
67 mustang suspention FatCat390 All Ford Techboard 3 05-11-2003 11:33 AM
Probe Industries
