From one Fred to another...
Hi there,
New to the forum but not B302's. Your B302 bell housing will bolt to any SBF, except early five bolt 260's and 289's. A 70 Boss motor is worth some good bucks, obvioulsy to someone restoring a 70 Boss 302. I recently sold a +.030(bare) OE 12 block, cast date, 12 May 1970 for $2500. A standard bore block is worth more. So, your complete set-up, to the right guy with the right car could bring between $5000-6000, if not more. If your block was a service block, like mine was, it wouldn't have been VIN stamped and be worth a bit more as it would not need to be milled prior to restamping. Also, that intake will only fit a B302 so try to sell it all together, otherwise you might get stuck with it.
Good luck
Fred
[/IMG]
