Those blocks are equivalent, with the '72 having a hair taller deck. This is useful when squaring the block to have enough material to do it without using thicker than normal gaskets - if necessary.
Unless you're building a fire-breathing monster, the whole basis for a 393 stroker is that it's cheap. No 'kit' required - just a crank. You use the rods from your existing engine and 302 pistons. Bingo - 393. There are several cranks on the market that are literally as cheap as having the old 351 crank remanufactured. So, the total cost is nearly equivalent to a stock 351 build. If you're going hotter, that's a different story, but a basic 393 in a 'bucket is a wild ride already.
David
