351w crank into 302w block
Its possible to do what you suggesting, the bore spacing is the same. Might be cheaper though to buy a crank from probe, they have a kit that will make 350 cubes. on a 30 over bore, a few more cubes if you go 60. You will have a lot of clearancing to do. And the rod, ratio is not favorable to longevity.
You could pay with it and maybe find a rod and piston combo that would work. But it all cost money. Triming the shock tower might look easy after you add up the dollars.
Besides a well built 347 can crank out some ponies, 380+ is realistic and attainable.. Mac[img]/phpBB/images/smiles/icon_razz.gif[/img]
