08-07-2003, 02:31 PM   #1 (permalink)
Svein
Bigger 460
Hi any one with info about stroker BB. What stroke can be added to -78 block without machining the block? What safe bore? Also looking to buy a set of heads for more power in to it.
Svein
-64 galaxie
Svein is offline   Reply With Quote
08-07-2003, 04:29 PM   #2 (permalink)
deleted2
Bigger 460
Is it a D1VE date code? If so a 4.5" crank will fit & it'll go .060 to .080 without checking it. 4.5" stroke & a .030 (4.692) bore is 545"!
04-28-2004, 04:10 PM   #3 (permalink)
OneQwikStang
Bigger 460
The only problem you might have is the main webbing on your block. I forget if '77 or '78 is the last year of the blocks with thicker webbing. You should look into this if if you're going to stroke it. I also recommend a main girdle if you're going to rev it past 6K.
OneQwikStang is offline   Reply With Quote
