351c blues
Maybe to late but here is an Idea, build a 393 stroker boss,
they are now grinding 3.850 stroked cranks with the 351C main bearing sizes and using a boss 302 piston, stock heads should work and a good 351 rod should work. If it was me I might use the 2V heads to help with bottom end power.sounds like fun and should come in around 400 horse with the right cam and prep on the heads. JE and probe would make custom pistons if needed [img]/phpBB/images/smiles/icon_ghey.gif[/img]
