02-22-2004, 11:32 PM   #1 (permalink)
aguilar102
352 FE
I'm looking to stroke my 352. I'm having a hard time finding out if their is a good combination or if I can even do it. Does anyone have suggestions?
aguilar102 is offline   Reply With Quote
02-23-2004, 12:10 AM   #2 (permalink)
deleted2
352 FE
Try a 390 crank. Scat makes stroler cranks for FE's now too. Make sure you have a decent set of heads...
02-24-2004, 01:22 PM   #3 (permalink)
jakengle
352 FE
Have the block sonic checked for bore thickness first. If it can go .050, then bore it to 4.050, and make a 390 out of it. Use 390 crank, rods and pistons. Read up on the FE forum (http://www.network54.com/Hide/Forum/74182) for all of the details on building these engines.
jakengle is offline   Reply With Quote
