Crank hitting oil pump!!!!
Yes, it is quite common. You will need to remove the pump and clearence it. Mark the spot where the crank is contacting it and grind it away. Go easy on the grinding, grind a little then test fit the part, grind again etc. You should have a minimum of about .050" inch clearence at the closest point.
Also, where the pump bolts onto the block, there is a cast in "loop" next to the pump mounting area, its a hole that serves no purpose inside the motor. It will need to be ground away as well. Hopefully, your motor is not all assembled because these things need to be done before final assembly. You dont want metal shavings from grinding in your assembly lube!
