07-07-2004, 09:52 PM   #1 (permalink)
MustangPower
Stroking a 302
Hi, I'm 14yrs old and I was wonderin what will I need exactly when or if I stroke my dad's 87 GT, while I'm in high school
MustangPower is offline   Reply With Quote
07-08-2004, 02:30 AM   #2 (permalink)
rustedduster
Stroking a 302
you will need a stroker crank, rods, and pistons. depending on what kit you go for you might need a 28oz. balancer and flywheel/flexplate. also some machine work on the block ie: bore/hone and possibly notching the oil pan rail and cylinder bottoms of the block for the added stroke of the crank.
rustedduster is offline   Reply With Quote
07-12-2004, 09:16 PM   #3 (permalink)
MustangPower
Stroking a 302
Thanks alot but that sounds like alot of dough how much could that cost if I had it done right?
07-12-2004, 09:37 PM   #4 (permalink)
rustedduster
Stroking a 302
the stroker kit itself usual goes for around $1200 to $1500 for a basic kit which usualy contains a crank, 8 rods, and 8 pistons (some kits are balanced others are not). im just taking a stab at it but machine work will probably run you $300-$1000 or even more, like i said im not too sure.
07-20-2004, 03:26 PM   #5 (permalink)
FALCONERR68
Stroking a 302
YOU MAY ALSO HAVE TO INCLUDE THE PRICE OF A CAM , INTAKE , CARB, AS YOU WANT TO MAKE IT PERFORM RATHER THAN STROKING IT AND ADDING STOCK ENGINE COMPONANTS .
FALCONERR68 is offline   Reply With Quote
07-22-2004, 10:39 AM   #6 (permalink)
tonys10sec306
Stroking a 302
Stroker kit
