08-07-2004, 10:34 AM   #1 (permalink)
lenh
hv pump
ok i built my 393 with intent to use hv pump but it wouldnt fit my fms oil pan so i put a standard pump in my question is should i mod the oil pan so i can use hv pump or use the standard oil pump[img]/phpBB/images/smiles/icon_confused.gif[/img]
lenh is offline   Reply With Quote
08-08-2004, 07:05 PM   #2 (permalink)
mustang420w
hv pump
depends on yours clearances.[img]/phpBB/images/smiles/icon_spongebob.gif[/img]
mustang420w is offline   Reply With Quote
08-08-2004, 09:10 PM   #3 (permalink)
tonys10sec306
hv pump
I have a stock pump on my 306
08-08-2004, 09:37 PM   #4 (permalink)
coolfalcon
hv pump
I have a stock pump in my 393 and it works just fine. All i did was push the little cap in to increase the pressure a little and restake it seem fine near 70 cold about 45 hot. Works for me.
09-11-2004, 12:47 AM   #5 (permalink)
1fstpny
hv pump
I agree, mine runs 60 psi cold, 50 hot. The bigs say 10 psi per 1000 rpms. But the 392 that I have doen't make squat
above 6000 so it works my shift point is 5500 rpms.
If your a fairly good welder you can add the 2" onto the pan, and run the hv pump..
Mac
[img]/phpBB/images/smiles/icon_smile.gif[/img]
