08-11-2004, 08:20 PM   #1 (permalink)
mpick
460 fuel injected stroker
I was thinking about building a 460 fuel injecteed stroker. I was wondering if anyone has done it and how much maching was required for the heads to get some real horses
mpick is offline   Reply With Quote
08-12-2004, 11:09 AM   #2 (permalink)
ckelly
You might sort through the postings here - could learn a lot.
http://www.network54.com/Forum/85220
08-13-2004, 11:11 AM   #3 (permalink)
tonys10sec306
A holley pro-jection kit would be the cheapest way to do it.
12-26-2004, 10:52 PM   #4 (permalink)
supercoupe460
THe cheap way to do it is get a TFI 351w distibutor and 460 gear a Painless wiring harness for a SEFI 302HO and computer ,but it will need to be reprogamed for the firing order.Get a fuel system to feed it and your done. I plan on going to 545 CID my self.
supercoupe460 is offline   Reply With Quote
10-28-2005, 11:37 PM   #5 (permalink)
EPYON
Is there any one with a hi-pro efi 460in here/
EPYON is offline   Reply With Quote
10-29-2005, 01:04 AM   #6 (permalink)
ujt389
if you have some money check out blower drive service and hilborn injection. They both make really cool looking injector manifolds (bith bug catchers and 8 stack types) that make tons of power.
10-31-2005, 12:26 AM   #7 (permalink)
EPYON
I barely got the carb on top ,and I don't want to put a hole or scoop on top.I all ready got the 351W dist. and 460 gear, the ecu out of a mustang coming next.
10-25-2008, 12:42 PM   #8 (permalink)
pvsheridan
Posts: n/a
Re: 460 fuel injected stroker
Expensive but very kool:
TWM Induction - V8 Kits (805) 967-9478
Click on Ford V8 kits link. Good luck, keep us posted.
