08-25-2004, 04:53 PM   #1 (permalink)
FHIprez
Stroking a \'79 460
I also posted this in the techboard because of more traffic, but I thought I'd post it here as well.
Does anyone know for certain if there are any problems stroking a '79 460? I want to go for a kit around 514 cid or so. I've never stroked a motor before so I don't know what if any machining is involved.
I wouldn't think machining would come into play unless I was looking for more cid than 514 or so, but I can't be sure. I do know that it should probably be checked for clearence when installed anyway.
I don't know what deck height my 460 is....most of the rotating assemblies I've seen say there are only for a 10.3" deck height. It is my understanding that the deck height increased a little bit over the years from the early 70's.
I do know that I will need to get a kit that is externally balanced on the crank. [img]/phpBB/images/smiles/icon_bs.gif[/img]
And lastly if anyone knows of a company they would recommend to talk to about this I'd appreciate that, as well as other companies that you may have dealt with or heard about that I should stay away from. Once again I'm a stroking virgin [img]/phpBB/images/smiles/icon_wink.gif[/img] so any input or advice is much appreciated. [img]/phpBB/images/smiles/icon_smile.gif[/img]
Thanks for your input,
Nick
FHIprez is offline   Reply With Quote
10-27-2004, 02:35 AM   #2 (permalink)
ccso640
Stroking a \'79 460
I found that using the early blocks, D1VE and older eleminate most of the machining. I'm using a 4.300 stroke crank with H-beams and it all went in fine. Also, it's scat stuff and works very well. Chris
ccso640 is offline   Reply With Quote
Probe Industries
