11-09-2004, 10:28 PM   #1 (permalink)
heathbeck
393 STROKER BUILD UP CHEAP
I am wanting to build a cheap naturally aspirated 393. I want 13:1 compression, or somewhere close. I am using pro topline 58cc 215 runner heads. Can I use 302 pistons with these heads(valve reliefs????)? what crank? what rods. I would like to use stock parts If I can. Please tell me what year model I can find these parts.
<font size=-1>[ This Message was edited by: heathbeck on 11/10/04 9:35am ]</font>
heathbeck is offline   Reply With Quote
11-10-2004, 01:00 AM   #2 (permalink)
TorinoStyle
Pro Line heads and 13 to 1 compression will kill stock parts in a hurry!.
Best thing to do is get a balanced rotating assy.
It will be cheaper and better than stock stuff.
TorinoStyle is offline   Reply With Quote
11-11-2004, 12:58 AM   #3 (permalink)
tonys10sec306
You can find 408 kits from $699
11-13-2004, 03:04 AM   #4 (permalink)
89 coupe
I'm using KB116 302 .200" dome hypereutectic pistons with my 392 and I have Pro Topline 215 that started life as 64cc chambers then were opened up to 68CCs then angle milled down to 52.5CCs. The valve relifs are deep and large diameter valve will work with those pistons. I got 15:1 compression with only a -2cc dome[img]/phpBB/images/smiles/icon_tup.gif[/img] The same pistons with your 58 cc chambers will put you near where you want to be and will handle a large .740" solid roller and will clear even 2.12" intake valve size(I tried it to make sure I can upgrade to 2.12" intake valves later when needed).
89 coupe is offline   Reply With Quote
