414 build
Hey guys & gals, I'm working on my little 414w out in the shop. This is the first one I've worked with so I didn't know what to expect. I'd done some 410 Chevy's and some other stuff (514 Ford, 496 BBC, 452 chrysler, etc) and was prepared for the worst. This thing is simple to put together. I did the homework, bought Mahle pistons, .060", 6.25" Eagle H beams and Scat 4" stroke crank. I was expecting to have to grind the pan rails, cylinders, main webs, etc....but so far I haven't had to much other than grind on the cheapie main girdle and the oil pump. I did do a 393 once, and it was a bit different...seems like the counterweights were bigger and they hit the pump and bottom of the cylinders on 4 holes only. Can't remember why...just know that a rod broke and destroyed the rest of it too (stock rods).
So, for you all trying to decide on whether to build a 393 or 408....go for the cubes! Not any harder to build, same prices, and best of all, more torque!
