06-22-2005, 04:35 PM   #1 (permalink)
daffylong
408 stroked 351W ????
I am wanting to build a supercharged 408 stroker from my 351W block. I am looking at Chevy aluminum rods (from a former Pro Stock truck engine,good to 1200 HP). What are the differences in the rod journal and wrist pin sizes? Will I be able to use the Arias forged pistons I already have or will I need to buy new pistons as well?
Thanks in advance Mike in Ga.
daffylong is offline   Reply With Quote
06-23-2005, 05:11 PM   #2 (permalink)
87stang
This is a race engine you're building, right?
06-23-2005, 06:30 PM   #3 (permalink)
daffylong
Yes, this is a race engine. I found out that the rod journals are 2.00 so I will need to cut the crank down.10 , right?
06-23-2005, 07:10 PM   #4 (permalink)
coolfalcon
Right which is a good thing. Less bearing speed.
06-26-2005, 02:34 PM   #5 (permalink)
mavman
Wow, a Pro Stock Truck engine that uses 2.00" BE's? I thought they were using Honda journals? (1.8-something)?
cool....didnt' know that!
06-26-2005, 04:46 PM   #6 (permalink)
fogged408w
NO NO NO
If the rod journals are 2" then they need a 1.8 or so crank BECAUSE you have to leave room for a rod bearing. So turning your crank to 2" would be a big mistake.
Also you need to know what the rod "width" is to make sure that too matches your crank.
5 second 1/8 mile
<font size=-1>[ This Message was edited by: fogged408w on 6/27/05 3:48am ]</font>
06-27-2005, 03:54 PM   #7 (permalink)
daffylong
Mavman,
apparently you are correct about the 1.8" journals. I might have understood it to be 2.0" but the crank would have to be cut to include rod bearing clearances? Is this something that a good machine shop would have known ahead or as I believe "you cut it to 2.00" , and need 1.8???"
Thanks guys.
