4.2 stroker
I have read about all the various stroker combos. I know that the 393 is the easiest and cheapest to do. I need max stroke for my 351W in my truck to pull a 3500 pounds trailer around town. I am going to do the 400M crank deal. I can get a lot of machine work done for free, along with the balancing of the entire assy. I realize that at 4.2, I will have some clearance problems to deal with. I plan on using a chevy 6.0 rod and 351 piston of the proper compression ht. I figure about a .022 cut, to gain zero deck. With a .030 overbore, I should have 425 cubes, or about 70 cubes in stroke over the stock 351.
I realize that I can buy a 4.17 Scat crank, but at over $600, I think I can do the 400M crank cheaper. Since I will not turn this motor beyond 4000 rpm, I see no reason for a forged crank. I gues I am asking if anyone has done such a project. If so, let me know what you came up against. If not then stay tuned. I will post my results, good or bad, pass or fail, on here for all to praise or laugh at me. Hope to hear from someone soon..............Rod
