You are not going to get into the tens with stock DOOE heads no matter what valves they have in them. Sorry to be brash,but it aint gonna happen. Here is what I would build for street/strip duty and reliability:
*393 or 408 stroker
*10.5:1 to 11.1 compression
*Victor jr or AFR 205 heads
*Hydraulic roller: something like .570-.580 lift
244-250@.050 int/255-260@.050 exh 110 lobe sep.
*Could also use similar Solid Flat tappet camshaft
*Victor jr intake
*780-850 carb.
Should be able to run premium fuel and have a decent idle(1000-1100 rpm) and turn no harder than 6800 rpm. Drawback is combo will require 4.11/4.30 gear and 3500-4000 stall converter. May have some trouble making good vacuum. Gonna be hell on the freeway. Should have a torque curve flat as a tabletop and move that car with ease.I honestly feel a better goal may be to shoot for mid 12's and you could use the heads you have(port work), a milder cam,gear,and converter. A good built 351W with either heavily ported DOOE heads or box stock AFR heads will easily run 12's all day long and drive home on the same tank of gas. Tim.
64 FALCON SEDAN
12.69@104.86 ON STREET TIRES
<font size=-1>[ This Message was edited by: 1QWIK64 on 12/7/05 11:13am ]</font>
<font size=-1>[ This Message was edited by: 1QWIK64 on 12/7/05 11:14am ]</font>
