03-24-2006, 06:33 PM   #1 (permalink)
DragRacr
What size carb ?
Any ideas on what size carb to put on my combo?
Here is my combo
408w, 11.7 to 1 comp. 4340 crank, h-beam rods, srp pistons
comp cam solid lift 240 , 250 @050, 586,593 lift
victor jr intake
1 3/4 inch super comp hookers,3 inch collectors
World product sr heads with some work
Car is 2950 with me in it
71 maverick 9 inch rear all strange
4.57 gears
pa super comp c-4
pa 9 inch 4500 stall
32x14x15 mt slicks
Also how much rwhp and fwhp do you think at what rpm?
I called pro-systems and they have to have an idea how much hp it has and how high im going to spin it ,so any info would help. I dont know yet where it will make most power at 6200 ,6400, 6600 any ideas? Or i could buy an off the shelf one if i knew about what size, 850hp,950hp? Hoping to run 10.50s or better.
thanks
DragRacr is offline   Reply With Quote
03-24-2006, 07:48 PM   #2 (permalink)
mstngjoe
What size carb ?
You'll want Patrick to set one up for you....
I'd say 550-600 FWHP if the heads flow a good number....you should probably be able to give him a ballpark on the shifting. Say 64-6600 or so.
I estimated several areas of the spec sheet I filled out for him. Haven't run the carb yet though.
03-24-2006, 07:53 PM   #3 (permalink)
DragRacr
What size carb ?
I have a 750hp. Do i send him that one or get a new one from him?
03-25-2006, 03:40 AM   #4 (permalink)
mstngjoe
What size carb ?
Check and see if he thinks the 750HP can get the job done with his setup/tune.
Mine has a custom base plate and a 780 main body.
03-25-2006, 07:33 AM   #5 (permalink)
DragRacr
What size carb ?
Ok thanks for your help. Once i get it all together ill post my times.
03-25-2006, 07:44 AM   #6 (permalink)
mstngjoe
What size carb ?
Good luck!
BTW, here's a pic of mine:
http://www.fordmuscle.com/pictures/p...joe_PSCarb.jpg
03-25-2006, 07:49 AM   #7 (permalink)
DragRacr
What size carb ?
Looks great with the billet base plate. Also thinking of buying some victor jr heads before i assemble the engine. Would buy afr heads but money is tight after building my motor.
03-25-2006, 07:58 AM   #8 (permalink)
mstngjoe
What size carb ?
Looking back on my guess on hp.....I'm probably high with the heads you have now. The Vic Jr would be a good choice and they have room for improvement down the road (porting).
MM&FF got 520hp out of the Vic Jr when they tested them in their big cylinder head series.
03-25-2006, 08:05 AM   #9 (permalink)
DragRacr
What size carb ?
Thanks, so you think the victor jr's will give me 550 rwhp?
<font size=-1>[ This Message was edited by: DragRacr on 3/25/06 11:06pm ]</font>
03-25-2006, 08:07 AM   #10 (permalink)
DragRacr
What size carb ?
Really , like i said trying to get it to run low 10's. Don't know what kind of hp that will take.
<font size=-1>[ This Message was edited by: DragRacr on 3/25/06 11:08pm ]</font>
Lakewood
