04-07-2006, 07:31 AM   #11 (permalink)
tonys10sec306
445
You made some hp number
04-07-2006, 06:17 PM   #12 (permalink)
93lx
445
I'm happy with it. I wish the torque was a tab more, but i really don't know whow much torque those victor race motors generally make.
corey
93lx is offline   Reply With Quote
04-07-2006, 09:46 PM   #13 (permalink)
bluelightning302
445
on the engine masters mag i have they tested a nitrous cam and it made almost an immeasurable amount more HP than a standard cam. (similar profiles) just an FYI
bluelightning302 is offline   Reply With Quote
04-07-2006, 10:24 PM   #14 (permalink)
ou812
445
With that much compression and camshaft, he NEEDS a nitrous cam!! Otherwise the heat would kill it...what caused the head gasket to let go?
05-28-2006, 07:34 PM   #15 (permalink)
93lx
445
I used the fel pro 1046 gasket and it appearred that the gasket leaked out on the top side og the gasket, near the edge. I don't know what caused it, but i recently put a set of the fel pro mls gaskets on there.
05-28-2006, 10:34 PM   #16 (permalink)
TorinoStyle2
445
Those MLS gaskets are even worse!!
Do it right, get the block and heads cut for 0-ring's and reciever grooves, and run a dead soft copper gasket.
If its blowing gaskets on just the motor pulls, imagine whats gonna happen when you push that button.
The 0-ring and copper gasket deal will handle anything you can throw at it.
TorinoStyle2 is offline   Reply With Quote
05-29-2006, 03:59 AM   #17 (permalink)
93lx
445
I actually had the copper titan gasket onhtere at first, but notice that the bore of the gasket was hanging over the cylinder a hair. both were 4.155 bore. I have not crank the motor yet with the mls, but if they don't work, i will definitely go to o-ring. That crossed my mind a hundred times before this,
corey
06-06-2006, 02:44 PM   #18 (permalink)
67falconer
445
15-1 compression and no o-rings maybe? [img]/forums/images/smiles/icon_smile.gif[/img]
What block are you using?
67falconer is offline   Reply With Quote
06-07-2006, 07:14 PM   #19 (permalink)
93lx
445
Sportsman 9.5 dart
09-05-2006, 01:09 PM   #20 (permalink)
drag79stang
445
Just a little fyi (at least it happened to me). I used to run copper head gaskets with 0 ringed block. Still wanted to poop past. (and wasn't even running juice back then).
And trust me, it had GREAT machine work performed............
drag79stang is offline   Reply With Quote
Powerhouse products
