347 Build/Questions
First Post, I have be lurking for awhile and I have read some real good info. To start, I had a 289 in my 65 mustang and it dropped a valve and did a nice job of taking out the whole motor. I was able to save the heads and cam plus all the external accersories. (65 289 castings, 54cc 1.94 1.60 valves, ported etc, Comp XE268 cam, 0.509 0.512, 224 230. I also have a weiand stealth manifold I saved....Im thinking of stepping up to a 347 for a new motor. A few questions were however is, 1) Is a 5.4" rod pretty much the rod length everone uses for a 347? I heard some people were using a slightly shorter rod so they could run a piston with a better ring package since the pin was not so close to the top. I was looking at a company (dixie mail order) with a short block consisting of a eagle steel crank, eagle I beam rods, and some KB forged pistons. I looks like the CR would end up being around 10:1 with my 289 heads. Any input wpuld be appreciated. Thanks
