Eagle Crank or Probe Crank...which to use in a Stroker build?
Probe uses RPM brand cranks, I have scene the radius in the corners not ground right on rpm cranks, no matter what crank you use.mic it and make sure its right.
The big issue is use a forged 4340 crank thats internally balanced. That 28oz counterbalance puts to much harmonics in the rotating assembly at high rpm.
To make it even tougher get it cryo hardened.
<font size=-1>[ This Message was edited by: Scotsman on 5/17/07 3:45am ]</font>
