oil level - oops
I would think you could measure down from the center line of the crank, taking into consideration the journal dia., the thickness of the rod, and the angle that the rod will pass through the pan area at.
Remember, you are only adding an extra .192 to the throw on the low side, it probably wont take much more than 1/2 to 3/4 of a quart to bring it down that far.
HTH
