Originally Posted by forthman
having built a 387 and a 393 now ..
I would go 408 my next build.
Most kits will come with better rods and a lighter better crank.
I like 351W's. I waved that flag years ago when nobody wanted them(early 80's). We were putting 400 cranks in them when nobody heard of that.
Let's address price first:
I paid $1800 for my FMS B514's fully assembled
I paid $1350 for my 4.300, H Beam Rod Crank Kit(Pistons rings bearings)
Latest Small block costs i have seen:
Comparable Heads $1200
Comparable Crank Kits - $1500
Weight:
All Iron 460 - 720 lbs.
With aluminum heads and intake - 600
I put my battery in the trunk!
Iron head 351W - 575 lbs.
Dimensions - 460 vs. 351W in 67-70 Mustang
460 - 27 wide, 34 length, 29 high
351W - 25 wide, 29 length, 29 high
2 inches wider, 2 inches longer front and back, same heght
Will fit in between your small block shock towers, headers custom made definately only drawback. Crites makes the Boss 429 style block plates. Sits the engine down in the car about an inch further back and inch lower.
I was Mr. Smallbock until a friend showed me the light on savings. My 521 will have cost me about $4200 for the long block, intake to oil pan. With 9:5-9.8:1 compression(pump gas), it will make about 600 real horsepower. How much for the same gains with a small block on 93 octane? Think about it.
It really depends on what you want. If I want it to handle like a Shelby, I don't know where you would drive it like that to show the significant differences in handling without drawing the attention of the law. if you want to dominate all in a straight line, is there any question.
Remember the reason people build stroker Small Blocks is to pick up the advantages of torque and cubes. Sounds like BB want a bees to me!
