08-03-2007, 06:37 PM   #11 (permalink)
seefour
Re: 427 Dart stroker
26 total
your car looks great
seefour is offline   Reply With Quote
08-03-2007, 07:00 PM   #12 (permalink)
gordon
Thanks. Yours looks mean. 26 is about the maximum any more and power starts to drop of. What sort of rockers are you using. Mine are T&D shaft mounted and I want to find out about welding the bases together?
gordon is offline   Reply With Quote
08-03-2007, 07:57 PM   #13 (permalink)
seefour
yeah I tried 28 on a chassis dyno and dropped off, started with 24 but made the best at 26 degrees. I"m running crower sever duty stainless rockers, nex tek springs 850 open 280 seat. probe stud girdles, manely studs. havent shifted over 7000 yet . 3 passes on motor.
mike
08-03-2007, 08:31 PM   #14 (permalink)
gordon
Yes, The CHI heads are very efficient
08-03-2007, 09:16 PM   #15 (permalink)
gordon
One thing I didn't mention, is with the high spring pressures I am running Torrington needle roller cam bearings with the block machined and special camshaft bearing sizes, 55 mm, The whole idea of the motor is reliability with plenty of streetable power. It will be at least a couple of months before I have it all running.
08-05-2007, 11:11 AM   #16 (permalink)
seefour
well you have a super nice car. good luck
Mike
09-13-2007, 02:42 PM   #17 (permalink)
plumber68
seefour where did you get the headers for your car? and what deck height is your motor?
its a pump gas all motor small block 302
plumber68 is offline   Reply With Quote
09-13-2007, 03:41 PM   #18 (permalink)
seefour
Tubular automotive, I know they are on the net but gotta look for them
1 7/8 x 35 x 3.5 ....they fit right in even with the CHI heads
9.2 deck height
09-14-2007, 05:46 AM   #19 (permalink)
plumber68
do you think they would fit on a 9.5 deck? also how much room do you have from the head to the shock tower?
Gordon what deck heigh are you running and who's headers do you have. im building a 9.5 deck with yates heads and trying to find headers.
09-15-2007, 02:40 AM   #20 (permalink)
gordon
I have removed the shock towers. It's a 9.2 deck height. I think Yates heads are even higher exh ports than the CHI heads which are about 5/8 inch higher. I am building my one headers with 1 7/8 stepped to 2 inch with 3 1/2 venturi collecters.
putting oil restrictors in a 331 stroker (dart block) pistoncrazy Stroker Engines 2 07-23-2006 02:31 AM
Dart blocks oldstangs Stroker Engines 4 01-07-2005 05:16 PM
Dart vs AFR Mario428 All Ford Techboard 4 12-11-2004 10:53 PM
Anybody build a Dart? RACERX#99 All Ford Techboard 0 10-24-2002 08:38 PM
Dart heads for 429/460 MGT351 All Ford Techboard 3 08-23-2002 07:22 PM
