09-19-2007, 08:49 AM   #11 (permalink)
dfree383
Re: SCAT vs Eagle 393 crankshafts
I've run both sucessfully, but the SCAT stuff has better quality control, better machine work and Tighter tolerances. IMO.
For the few extra $$ go with the SCAT stuff, sometimes the eagle stuff is more difficult to balance, needs some attention to dimensions, Ect.
09-20-2007, 06:45 PM   #12 (permalink)
skyy
what kind of rods do you have ? unless you already have really good rods you can probly buy a kit with great compononts cheaper than buying good compononts seperate. try adperformance, they have good prices
skyy is offline   Reply With Quote
09-21-2007, 09:44 PM   #13 (permalink)
k718cougar
I already have a set of Eagle H-beam rods that's why I'd like to save money and not buy something else to replace what I already have.
Racing Cougars (the other Mustang) for two decades...
k718cougar is offline   Reply With Quote
09-22-2007, 11:47 AM   #14 (permalink)
skyy
becouse buying a kit is like getting the value meal at mcdonalds its like buying everything els and gettind the pisons for free .
however if you have good rods , and it sounds like you do your probly better of buying the rest of the components, if you had I beams or stockers i would say scrap them and buy a kit , thats why i asked what kind of rods you have
09-24-2007, 07:18 PM   #15 (permalink)
forthman
I have run my Hawkins crank, broke a couple of pistons and bent a rod. Crank keeps on turning.
If i build anothe stroker i will go 408 or 418.
The stock TRW pistons even though forged are not up to the task. In my opinion.
The 408's seem to make more power and at about the same price.
I only went 393 because i had a set of stock bore 302 TRW's and a good 351w stock bore block and rods.
1966 Stang Coupe Org. 6 cyl. 351w,Sealed Power Hypers, ARP bolts,Total Seal rings,Eagle H-beams rods,Balanced,Hedman long tubes, Pro Comp 2.05/1.60 Heads, Shaft roller Rockers, Victor Jr intake, Holley 750 DP, Ed Nix Custom .600/.600 254/258 @.050 Solid Cam, Crane solid roller lifters,Richmond 4.11, Strange mini spool, Modified C4, 3500 stall, Redneck Transbrake, B&M Hammer shifter, Shelby lowered, Pro Comp 6Al system. Mickey Thompson 275/50 Et Street Drag radials.
Scat 331 vs. Eagle 331 rcm600 Stroker Engines 23 06-01-2007 07:34 PM
Scat vs Eagle kgoessling All Ford Techboard 11 11-15-2005 05:04 PM
Scat Vs. Eagle N2wheelinxjs All Ford Techboard 12 01-04-2005 02:07 AM
Probe (CHP) vs. Eagle vs. Scat vs. ? 63SportsCoupe All Ford Techboard 14 12-01-2002 07:14 PM
"H" beam rods......any difference between Scat and Eagle? Cman All Ford Techboard 3 08-19-2002 02:08 PM
Powerhouse products
