10-06-2007, 08:26 PM   #1 (permalink)
165falcon
what heads to use
I need some opions on what heads to use on my 347, I have a fresh set of 68 closed chambered heads, but thinking I might what to go with alum. trick flow heads? by the way the blockis a 91 5.0 and its going into my 65 falcon
165falcon is offline   Reply With Quote
10-06-2007, 09:55 PM   #2 (permalink)
ou812
Re: what heads to use
Well it depends on what your doing with it. Give us some more info, like pumpgas, race gas, compression, power you want, etc....
www.immengines.com
10-07-2007, 10:24 AM   #3 (permalink)
165falcon
I would like to have it set up for the strip mostly run race gas and nitrous, not sure about compression ? thanks for your help
10-07-2007, 11:42 AM   #4 (permalink)
ou812
We sell trickflow heads, and I can tell you the cnc ported TW heads produce very good power.
I know the afr's do too, but I like Tooleys work and he's got a ton of championships under his belt. It's his cnc work that TF uses.
I would say you need an rpm range, and then pick the head that will work in that range. Start there...
www.immengines.com
10-07-2007, 12:21 PM   #5 (permalink)
BIGJOE
NO ONE beats AFR for the most bang for the buck ( dollar )I have made 649 HP with out of the box AFR 205 heads on a 347 engine. That is HARD to beat.
JOE SHERMAN RACING ENGINES
10-07-2007, 06:43 PM   #6 (permalink)
ou812
Is that right out of the box, or with some work?
www.immengines.com
10-07-2007, 06:54 PM   #7 (permalink)
Spali32
I believe he just stated the AFR205's were right out of the box...must of been a big cam making that power. Would of loved to hear that thing rumble.
www.spalisautodetailing.com
347 Stroker/XE284H(284/296 dur, 240/246 dur @ .050), BG 650 VS Speed Demon, Ported Victor Jr intake, Jack Roush World Jr Heads (ported from 180cc to 195cc)(upgraded to 2.02/1.60 valves) 260cfm/190cfm @ .550 lift, 11:1 comp...309rwhp for now:):)
10-09-2007, 06:07 PM   #8 (permalink)
BIGJOE
We are a little off base here. The cam was a custom grind, like 268-276-700 lift, HP peak was at 7500 RPM, Funnelwen, 1050 carb.12.75 to one, 1 & 7/8 headers. The heads were untouched, except cut for bigger sprrings, Jesel shaft rockers.I reved it up to 8000 RPM, sounded goood.
D0OE 351w heads to C8OE 302 heads james302 All Ford Techboard 0 04-03-2007 12:00 AM
Edelbrock Performer RPM Heads Are they good heads? Lupins All Ford Techboard 9 03-23-2005 08:00 AM
anybody looking for boss 351 heads/351c closed chamber heads? XolieX All Ford Techboard 1 01-01-2004 08:12 AM
Difference between 69 351w 4bbl heads and 2 bbl heads? growlin351w All Ford Techboard 3 11-29-2003 10:41 PM
1966 289...stock heads or 351W heads? Scooter All Ford Techboard 13 09-03-2003 07:24 PM
