12-30-2007, 06:03 AM   #1 (permalink)
jmckinney
73' 302 block
Are the old 73' and 74' model 302 blocks just as good to use for the strokers? or do you need a newer model block?
jmckinney is offline   Reply With Quote
12-30-2007, 02:21 PM   #2 (permalink)
wagesofsin
Re: 73' 302 block
waddya wanna make out of it? are ya gonna flog it daily? if you use quality parts, it should take up to a 347 fine.
wagesofsin is offline   Reply With Quote
12-30-2007, 05:44 PM   #3 (permalink)
woody1
Re: 73' 302 block
no different than a late model block, a tad stronger.
FordStrokers.com : Owner
SBFTech.com : Owner
Quickly Becoming The Largest CHP/Probe Dealer
woody1 is offline   Reply With Quote
12-31-2007, 01:49 AM   #4 (permalink)
Spali32
Re: 73' 302 block
My 302 block came out of a 72 Ranchero with 140HP. It's a 347 now and pushing around 450HP. Strong as an ox.
[URL="http://www.spalisautodetailing.com"][SIGPIC][/SIGPIC]www.spalisautodetailing.com[/URL]
347 Stroker/XE284H(284/296 dur, 240/246 dur @ .050), BG 650 VS Speed Demon, Ported Victor Jr intake, Jack Roush World Jr Heads (ported from 180cc to [B]195cc[/B])(upgraded to 2.02/1.60 valves) 260cfm/190cfm @ .550 lift, 11:1 comp... 450-475HP
12-31-2007, 02:54 PM   #5 (permalink)
jmckinney
Re: 73' 302 block
Thanks guys! Yea I'm getting my specs together,but I think I'm going with the 331 stroke .I hear it lasts longer than the 347?I want to go with the 12,5:1 comp. with the 58cc heads and a solid roller cam.I've been running a c4 behind a 302 with a bigger edlbrock cam and a 750 holley and a 100 shot of nos.It was an old motor that sat in the pasture for 12 years.Its blowin by one of the intake valves now.So its time for a rebuild.Is there some kind of marking in the block to show if its a mexican block and are they supposed to be better?
12-31-2007, 03:08 PM   #6 (permalink)
jmckinney
Re: 73' 302 block
My ride at Texas Motorplex!
12-31-2007, 03:21 PM   #7 (permalink)
kgordonl
Re: 73' 302 block
You'll find that all of the "big-time" engine builders swear by the 347's! Joe Sherman (Joe Sherman Racing Engines) has expressed his strong preference for a 347 over a 331 many times. They cost the same, last the same, so why not go for the longer stroke and extra cubes???
The same logic applies to the 408 vs. 393 debate... I apparently like living on the edge, so I went with the 418!
12-31-2007, 04:22 PM   #8 (permalink)
woody1
Re: 73' 302 block
So if you need more rpm to make a 331 do the same work as a 347 at lower rpm, which one will live longer? Build the 347
SBFTech.com : Owner
12-31-2007, 04:34 PM   #9 (permalink)
scottford351
Re: 73' 302 block
Me too. It's really a 424 (.060)
Its just a pile of parts at the moment.
I'm shooting for 6.20 in the 1/8
scottford351 is offline   Reply With Quote
12-31-2007, 09:23 PM   #10 (permalink)
kgordonl
Re: 73' 302 block
I went .060 over on mine also, so it is actually a 424 as well. I'm sure that the rod ratio argument is valid, but I've talked to several people who have been running 418 and 427 stroker Windsors for years without any issues related to the rod ratio. Mine is a street car that will not be reving much over 6,000 rpm, so I took the chance in exchange for more cubes.
Big block radiator with small block 1968 9t3lightning Galaxie Pages 1 10-28-2007 02:32 PM
New 8.20 sbf boss racing block vs worlds block stoker All Ford Techboard 35 12-06-2006 09:23 PM
E7TE small block heads on C8OE block Kman All Ford Techboard 6 06-08-2006 09:40 AM
351W lightning block vs standard roller block mustangzrule All Ford Techboard 6 08-27-2004 08:53 PM
Anyone use a big block fuel pump in a small block? mc All Ford Techboard 4 04-21-2003 02:34 AM
