01-01-2008, 08:24 PM   #1 (permalink)
GSP393
Which carb for my 393?
I'm trying to decide on a carb for my 393. The Holley website says 800-850 cfm, I'm leaning towards the 850. I've thought about an 830, but I want to run a choke and the Holley doesn't have one.
I've got a stroked 351w, forged flattops, Weiand Stealth intake, 210cc/58cc
2.055/1.60 Canfield heads, 600+ lift cam with a 5 speed.
Carb guys please chime in.
Thanks, George
GSP393 is offline   Reply With Quote
01-02-2008, 11:10 PM   #2 (permalink)
ou812
Re: Which carb for my 393?
I like the 950HP but no choke. If you need a choke, go 850 and downleg boosters.
Brian
www.immengines.com
01-03-2008, 02:16 PM   #3 (permalink)
GSP393
Thanks Brian, I'll look into that.
01-03-2008, 03:06 PM   #4 (permalink)
dfree383
Why do you need a choke?
01-28-2008, 05:08 AM   #5 (permalink)
Chris_Curl
750 cfm is more than a 393 can take in. if the carb can actually flow it, then a 750 should be plenty, especially if it is a street car.
CFM needs
i like the quick fuel carbs
Black 1967 Fairlane GTA convertible ... restoring to stock
Black 1995 Mustang convertible ... 410 stroker, AFR 205s, AOD ... a perpetual work in progress
Chris_Curl is offline   Reply With Quote
01-28-2008, 06:38 AM   #6 (permalink)
kgordonl
I had concerns about not having a choke when I bought my carb as well. However, with flattops in that engine you should have very healthy compression which leads me to agree with dfree 383... "why do you need a choke?" I have 10:1 compression in my 424W with a BG 850 Holley with no choke, and on a 30 degree morning after not having been cranked for a week, one pump on the gas and it will fire up immediately every time!
If you don't already, you may want to just make sure that you have a good starter to turn over all that compression!
'67 Mustang Coupe
424W-KB Forged 10.2:1-AFR 205's-Victor Jr.-Mighty Demon 825-Comp Cams hyd roller.236/.242 .555/.576-Miller rockers-Hooker Super Comps-3" exhaust-Gene Hughes AOD-3.55 Posi-4 wheel disc brakes
Carb accel pump adjustment. Carb Help 51truck All Ford Techboard 3 05-31-2005 01:42 AM
Which carb float for this carb? beegshot All Ford Techboard 2 06-10-2004 03:05 AM
489ci FE with a Vortec Blowthru Carb Setup Dyno\'d (Great Carb Tech) n2omike All Ford Techboard 12 03-31-2004 02:53 AM
Demon carb q`s-TPC,Bigs and carb guru`s Nastystang All Ford Techboard 8 04-08-2003 03:59 PM
CARB TUNING:All carb "Experts" leave your "Tuning" secrets here!Then we'll all be able to tune'em gtfordified All Ford Techboard 15 04-27-2002 12:26 AM
