01-02-2008, 03:54 PM   #11 (permalink)
$arge
Re: "big" cam on 390 timing???
ok so vacumm gauge on the manifold to get a reading of 10 lbs or so, or until it becomes unstable. cool. now i just have to find a vacuum gaude...
the distribuitor seems stock with the pertronix point replacement and the retarded P.O. pinched and sealed the vacuum advance!!!
$arge is offline   Reply With Quote
01-02-2008, 03:57 PM   #12 (permalink)
dfree383
You may want to pull the dist and take it to some one with a distributor machine and check the curve and make sure everyting is working correctly.
01-25-2008, 12:40 PM   #13 (permalink)
$arge
well i did the vacumm thing, i did the timing light thing, and i did the timing by ear, the best was run it up and turn, where it runs crappy mark it, retard it and wher it runs crappy mark it, place in the middle then drive and adjust drive and adjust. the dieseling problem i had was maybe fuel related im runnin 87 with octane booster, when thats out ill run 87 by itself, if it diesels again ill try mid grade. 390's after all is a high compression engine+cam= frustrated owner.
but its all good now i hope.
Raf
thanks for the help guys
01-25-2008, 12:43 PM   #14 (permalink)
dfree383
You need to run better gas........
01-25-2008, 02:16 PM   #15 (permalink)
$arge
where were ya before......ha ha
01-25-2008, 04:33 PM   #16 (permalink)
FALCONAROUND
Nope, that's not what I said...
I said to set the timing at around the 10* mark then start it and get it nice and warm.
THEN you put a vacuum gauge on the manifold and adjust your timing until you get the highest STEADY vacuum reading.
Once there just back off the timing a couple degrees and you should be perect.
FE
When my Gecko is broken, does that mean I have 'A REPTILE' Dysfunction?
1977 LTD II, S-code ["SPORT II" clone project] $1200 MERCURYMUSCLE Vehicles for Sale 1 01-14-2008 05:28 PM
Disc swap prop valve, "T" fitting questions ? lgh1157 All Ford Techboard 3 01-01-2008 11:28 PM
"The Mighty" 1963 Ford Falcon at Pueblo FATNFAST FM Video 8 12-17-2007 12:29 AM
Scat 4340 forged 4" stroke 2.75" main FullAuto Parts for Sale 1 10-19-2007 06:51 PM
"Victory by Design" on Speed, Ford Muscle series ga289stocker The Garage 0 07-08-2007 10:35 AM
