01-09-2008, 05:59 AM   #11 (permalink)
347GTVERT
Re: WTK: 347 Stroker, are my heads too small?
I have TFS TW heads on my 347 also. At first I thought they might be a little on the small side for my motor. After talking with my builder and reading alot of info on cross section of heads, it seems as though the TFS TW & AFR 185 are the most compared heads have an almost equal cross section. It seems that the 185's have a slight edge over the TW heads in OOTB conditon, but you can have a lot of head work done to the TW. It seems there are very few reconized people who can work an AFR head and have a huge increase. I also will be running boost later on, and I dont see why I cant make 600rwhp on pump gas with those heads and 15lbs of boost. Most of the info I got were from the cam grinder web sights ( flow tech induction - Ed Curtis & camshaft innovations - Jay Allen )
347GTVERT is offline   Reply With Quote
01-09-2008, 07:28 AM   #12 (permalink)
valleyfirearms
Thanks kgordonl. I will call them and ask that question. I'll keep you posted.
Thanks!
Mike.
01-09-2008, 07:44 AM   #13 (permalink)
dfree383
Are you racing or building a street car?
01-09-2008, 09:53 AM   #14 (permalink)
valleyfirearms
It will be a street/show car.
Thanks!
Mike.
01-09-2008, 10:07 AM   #15 (permalink)
dfree383
They are fine then, Don't waste your time on bigger heads, typical street car can't even come close to hooking up the kind of power your going to make even with the small heads.
Your Combo is fine, don't worry about it !!!
01-09-2008, 03:44 PM   #16 (permalink)
valleyfirearms
Excellent! I looked the JE pistons up on Summit. Theya re the 232462 pistons. The piston is a dish w/2 valve reliefs. Compression distance is 1.100 in., and the piston head volume is +22.00cc. Now all I need to do is find out what PBM rods I have. I begining to think they are Chevy rods. Each rod and cap is numbered differently and don't correspond to any of PBM's numbers. Maybe they are from an older subcontractor that they don't use to make the rods anymore. I will call them tomorrow. Also I called Holley and they are closed. I need to ask them about my carb and confirm the pistons.
Thanks!
Mike.
01-09-2008, 05:48 PM   #17 (permalink)
kgordonl
Well what do ya know! My eyes must be going bad because those pistons didn't look like they had that kind of dish in them from the picture!
Well, at least now you know exactly what you have. According to JE, you actually have a 348 (.040 over) and are still right at 9:1 with 61cc heads. I would imagine that you have 5.4" rods. Never hurts to be sure though!
You must have called Holley at 4:01!
Anyway, as long as the rods are what you think they are and Holley says that 9:1 is okay for your blower, I'm with dfree383, I would go with what you have.
'67 Mustang Coupe
424W-KB Forged 10.2:1-AFR 205's-Victor Jr.-Mighty Demon 825-Comp Cams hyd roller.236/.242 .555/.576-Miller rockers-Hooker Super Comps-Gene Hughes AOD-3.55 Posi-4 wheel discs-400rwhp/405rwtq
01-09-2008, 09:31 PM   #18 (permalink)
valleyfirearms
I will definitely keep you posted
Thanks!
Mike.
01-28-2008, 06:34 AM   #19 (permalink)
sbrickell
Any updates / feedback from Holley?
http://1967stang.com
sbrickell is offline   Reply With Quote
01-28-2008, 10:38 PM   #20 (permalink)
valleyfirearms
I did talk to Holley and they said to reference the power valve. Attached is the pic they faxed me. So I took my Pro-Form apart and wa la, they are different. I got in touch with ProForm and they referred me to their carburetor techs. They told me to just drill a hole in the side of the base plate to the powervalve port and get my vacuum from under the blower (manifold). You have to block off the powervalve port under the new vacuum line (where it goes through to the bottom of the base plate). So, essentially you will now be getting your vacuum from the manifold and not from under the blower.
Thanks!
Mike.
427 small block stroker ? fastcoupe68 All Ford Techboard 6 08-30-2007 07:19 PM
460 Small block, heads? samh All Ford Techboard 12 05-04-2006 11:25 AM
SMALL BLOCK HEADS KIPK All Ford Techboard 6 04-24-2006 04:01 PM
small block stroker VS. 351 windsor mikemustang289 All Ford Techboard 14 06-26-2005 10:37 AM
Preparing small block for stroker kit Paul78Zephyr All Ford Techboard 8 04-21-2005 03:36 PM
