01-06-2008, 08:23 PM   #1 (permalink)
95cobra5.0
347 radiator
I am planning on putting a 347 in my 95 cobra. Will overheating be a problem with the stock radiator. If so any recommendations on what type I should get. Thanks.
95cobra5.0 is offline   Reply With Quote
01-07-2008, 04:05 PM   #2 (permalink)
87stang
Re: 347 radiator
It could be, but it might not be. There are many factors like, air conditioning, climate, thermostat used, power-adder, etc.?
If you do go aftermarket, I've had good luck with Fluidyne.
Dave
\'87 5.0 LX Hatch, 5-speed
Cobra brakes
CHP 347
01-07-2008, 09:37 PM   #3 (permalink)
GrandSAC
Re: 347 radiator
I had to replace the radiator (dual core 1" tube, aluminum), high performance water pump, and high flow thermostat. The radiator alone didn't make a huge impact in my case.
'89LX, 347 Probe stroker kit, Victor Jr. heads and intake / 650 Speed Demon, T5, 4:10/8.8, MSD ignition, Crane hydraulic roller cam, BBK 1 7/8 long tube headers.
GrandSAC is offline   Reply With Quote
01-16-2008, 09:24 PM   #4 (permalink)
focusgm
Re: 347 radiator
Cobra,
I installed a 347 w/E303 cam in my 84 stang conv. and under certain sumertime driving conditions in central Missouri, my stock 2 row radiator just wasn't getting the job done. I found a great 3 row replacement from our local Autozone store and the price was easy on the wallet. If you purchase one, you will more than likely have to make minor modifications to the mounting rubber grommets that the stock 2 row radiator set on. Since the 3 row is thicker, you will have to cut an appropriate slot into the rubber mounts. This is an easy fix!
Good luck,
Focusgm
focusgm is offline   Reply With Quote
Radiator #? ACESN8S Galaxie Pages 13 09-28-2007 01:43 PM
5.0 radiator? vintagespeed Galaxie Pages 8 08-16-2007 10:53 AM
64 radiator scvpiper Fairlane Pages 3 01-30-2006 09:03 PM
I need a new radiator. Will a mustang radiator fit in a 64 289 Galaxie? norcal500 Galaxie Pages 4 09-23-2004 12:38 AM
Oil in The Radiator Blue Thunder All Ford Techboard 2 11-09-2002 07:19 PM
Powerhouse products
