Re: New here and my recently rebuilt engine went
With 185 heads and a blower, you could easily get past 500 HP. If that is your goal, then you should look into an aftermarket block.
If you are only looking for 450 HP, sell the paxton, buy the 185's and you will have a great engine with what you have.
Assuming there is no damage in the lifter gallery from the bent push-rods. Sounds like the wrong length p-rods were used. Did you figure out why they bent on you yet?
[SIGPIC][/SIGPIC]
