Re: 393 Build up questions
for the low rpm / high torque application, I wouldn't waste the money on forged pistions, Hypers will be better and tighter clearances will benifit you. Keep the compression under 9-9.5 if your towing any real weight.
Some Smaller Heads Like Brodix SR 5.0, GT-40X, AFR 165 / 185, Edel RPM's Ect should work great under 5000 rpm on a 393 / 408
