02-22-2008, 08:16 PM   #1 (permalink)
L n L
Distributor gears - bronze vs. polymer??
Hey Gang,
Using a solid roller cam, and need to select the distributor gear.
Car will be street and strip, maybe 5,000 miles a year. I've used bronze gears in Pontiacs, but they have an oil plug that can be drilled for a small stream of oil to shoot right onto the gear, and gives them good life.
Anyone have experience with either the bronze or polymer gears in a Windsor?
Thanks,
Lee
02-23-2008, 11:52 AM   #2 (permalink)
hotrodconsolo
Re: Distributor gears - bronze vs. polymer??
i ran a polymer gear on a comp solid street roller. expect about 8000 mi then they break. never ran a broze gear. went to a steel gear and it is fine now.
70 bronco 408 finally!
65 falcon
67 fairlane (future project)
69 el camino, dads
70 camaro, dads
hotrodconsolo is offline   Reply With Quote
02-23-2008, 12:14 PM   #3 (permalink)
mrtbolt64
Dont do it. That gear also has to turn the forces of the oil pump, stick with the bronze gear. There is a mod for the ford aswell for tapping into the oiling system for the gear
1992 mustang lx coupe, caged, mini tubbed, 393 with Novi2k supercharger 11lbs of boost, BS3 EFI on 93 octane. 9.47 @144
1997 F350 psd 4x4 http://media.putfile.com/Mustang-Novi2k
mrtbolt64 is offline   Reply With Quote
02-23-2008, 04:34 PM   #4 (permalink)
L n L
Thanks guys, I'll stick with the bronze for now.
The shortblock is already assembled - too late to do the "oiling" trick?
Lee
02-23-2008, 05:02 PM   #5 (permalink)
dbu8554
As far as I knew for a roller cam you had to use a steel gear because bronze ones get eaten by the steel on the cam
02-23-2008, 05:30 PM   #6 (permalink)
71hotrodpinto
The only cam thats compatible with a steel gear is the ford letter series. For example the E303,B303,Z303 cams etc.
Aftermarket Roller cams are of a harder billet steel and are allegedly too hard for the steel gears that ford sells.
Aftermarket billet roller cams require a bronze or the newer composite gears.
In all honesty though, call the cam manufacture for the best answer.
71 Pinto V8 lifelong project.
02-23-2008, 05:38 PM   #7 (permalink)
CWallace
What pinto said call the cam company or grinder if custom. I have been told if you run a bronze gear when you inspect it and it will let you know if something is wrong in the valve train. Good luck.
CWallace is offline   Reply With Quote
Distributor Gears CWallace All Ford Techboard 6 08-04-2006 04:42 AM
Distributor gears smokey212 All Ford Techboard 9 03-02-2005 10:15 PM
Distributor gears, which one to use? BLstangin All Ford Techboard 2 03-23-2004 12:17 AM
Polymer distributor gears - are they good/strong ? ville All Ford Techboard 11 11-30-2003 07:42 PM
Distributor gears? coupe3w All Ford Techboard 15 11-13-2002 05:30 AM
