02-27-2008, 12:34 PM   #1 (permalink)
395nzder
438 Sbf Stroker
Im looking at building a big inch small block using
4.1 stroke crank
4.125 bore (dart Block)
super victor manifold
custom solid roller cam
pro systems dominator carb.
But my main question is i already have a set of AFR205 heads
that have been set up for a solid roller with manley vavle train goodies
will these heads be enough for this size of stroker or will they just choke it up.
Car will be used mainly on the strip but buzz down to the local burger bar and the odd club cruise nights
[img]http://www.fordmuscle.com/pictures/395nzder/dec05.jpg[/img]
395nzder is offline   Reply With Quote
02-27-2008, 12:39 PM   #2 (permalink)
frdnut
Re: 438 Sbf Stroker
Those heads are going to be pretty small for that engine..I would think you would want something in the 225+ runner size area.
02-27-2008, 04:04 PM   #3 (permalink)
BIGJOE
Re: 438 Sbf Stroker
There is VERY little differance between the two size heads. I have made 667 HP from a 408 engine on pumpgas, with the 205 heads. I know that wont be your problem At the most you MIGHT see 10 to 20 HP differance, probably less.
JOE SHERMAN RACING ENGINES
02-28-2008, 09:57 PM   #4 (permalink)
395nzder
Re: 438 Sbf Stroker
Hi Joe
So the 205 heads would be more suited to the smaller strokers around the 393 to 418 cui. I have a 3.850 stroke crank availble to use so would a 411 cui be my best shot to use with the 4.125 bore block im sort of chasing around the 650hp range. Also what would be a safe comprission ratio to use with 98 pump gas thanks
4.2 stroker rfb92345 Stroker Engines 1 11-16-2005 01:51 PM
408 STROKER BIGNICK Stroker Engines 2 11-07-2005 07:09 PM
400 stroker kit zach All Ford Techboard 1 08-14-2004 12:14 AM
Stroker 408 1tfischer All Ford Techboard 4 05-11-2004 07:34 AM
347 or 408 Stroker? Tigly2 All Ford Techboard 11 10-15-2002 03:14 AM
Holley
Probe Industries
