03-17-2008, 09:57 AM   #11 (permalink)
scotternaz
Re: 351 Cleveland rebuild
I have thought it though. I do not want to make a stroker out of her. I want to just do a small over like a .030 the do a little more work on the bottom end. I still would like to know if there any parts companies that you guys feel have the best parts for the Cleveland. I would also like to prob have a hydraulic vs solid mainly because i do not want to keep adjusting the valves.
scotternaz is offline   Reply With Quote
03-17-2008, 10:10 AM   #12 (permalink)
dfree383
As far as stroker kits, Scat make some good stuff.
Carb wise a 650 is way to small, you'll be looking at a minimum of a 750 and best power on a 408" motor using a 850-950 sized carb, but it all depands on your part selection and RPM Range you want to turn it.
If your not going to do a stroker, at least look at getting better heads than your 2v Factory Parts. The Edlebrocks are definetly a much better alternitive.
03-17-2008, 11:05 AM   #13 (permalink)
scotternaz
I am leaning towards the CHI 2v heads. at the moment. any thoguths?
03-17-2008, 11:14 AM   #14 (permalink)
scotternaz
I am also looking at low 6k rpms since i would like to use a hydraulic cam.
351 Cleveland Rebuild sthomp29 Stroker Engines 9 07-18-2008 08:28 PM
351 Cleveland Rebuild sthomp29 Torino Pages 8 03-23-2008 12:14 AM
Cleveland Build (...Mr. Cleveland post) slik All Ford Techboard 55 12-16-2007 02:23 PM
351 Cleveland rebuild questions TorinoLane All Ford Techboard 10 06-10-2007 09:20 AM
351 Cleveland Rebuild NEED HELP machI1973 All Ford Techboard 3 10-09-2002 11:32 PM
