04-25-2008, 07:30 AM   #1 (permalink)
dano610
Oil Pump Install Question
I have a simple question for all you race engine builders? I am assembling a 408/351W race motor and installing the oil pump to block. Do I use a gasket between the pump and block? I can't remember if there was one on the motors that I have done before, it has been awhile since I put one together. Any help would be appreciated.
Dan
dano610 is offline   Reply With Quote
04-25-2008, 09:00 AM   #2 (permalink)
dennis111
Re: Oil Pump Install Question
Yes, there should be a gasket between the pump and the block--it is normally included with the pump. I have taken some old stuff apart and did not find one. The possibility of a leak is too great without one for my tastes.
Whatever you do, do not use silicone as a replacement.
Dennis
11.52@121.29mph
04-25-2008, 09:02 AM   #3 (permalink)
I recommend a thin paper gasket. You WILL find it in a "Full Set"...
04-25-2008, 10:29 AM   #4 (permalink)
dano610
Thank you guys for the responses, I just didn't remember there being one between the pump and block on tear down. Is there a chance of the gasket blowing which would be worse than a leak.
Dan
04-25-2008, 10:30 AM   #5 (permalink)
Not likely!
Where do I install my Fuel pump cut-off switch? strtcar All Ford Techboard 3 02-10-2007 03:47 PM
HOW TO PROPERLY INSTALL OIL PUMP INTO OIL PAN ? SCHOONER Truck Forum 1 10-30-2006 07:42 AM
351c-2v and oil pump shaft install dbrine All Ford Techboard 19 05-21-2005 09:29 AM
New Water Pump install advice 68stanger All Ford Techboard 16 05-02-2004 10:34 PM
385 Series ... water pump install MonsterMach All Ford Techboard 12 01-04-2004 11:53 AM
Hays Clutches
Holley
