04-26-2008, 11:33 AM   #1 (permalink)
dano610
408 Stroker Oil Pump
I am having problems installing my oil pump on my 408 stroker. I have a Melling 10833 pump and it does not clear my stud girdle or the crank. Is there a special pump that you have to use to get this to install? There is no way this pump will fit even without the girdle. Any ideas?
Dan
dano610 is offline   Reply With Quote
04-26-2008, 12:13 PM   #2 (permalink)
woody1
Re: 408 Stroker Oil Pump
use a regular ole' M83 or M83HV
FordStrokers.com : Owner
SBFTech.com : Owner
Quickly Becoming The Largest CHP/Probe Dealer
woody1 is offline   Reply With Quote
Smog Pump as Vacuum Pump?? jrosengarth Late Model EFI Techboard 5 04-30-2007 10:50 PM
1965 289 water pump question (aluminum pump) wildosvt01 All Ford Techboard 4 04-14-2007 03:18 PM
electric fuel pump vs. manual fuel pump JoeD All Ford Techboard 13 06-30-2005 06:23 PM
408 stroker front lobe of crank hitting oil pump. 83coupe408W All Ford Techboard 6 05-26-2004 12:28 AM
Mechanical fuel pump VS. Electric fuel Pump growlin351w All Ford Techboard 16 08-01-2003 08:28 PM
Hays Clutches
