05-04-2008, 01:08 AM   #1 (permalink)
4Lowie
Compression and cam timing
Hi all. My 347 is being built for a road car (65 Mustang). My question is, can I run hi compression and keep the cam timing mild to make it nice and drivable? Was think the hi compression would help make hp, mild cam timing would keep it drivable.
Thoughts please.
Thanks, Dave
4Lowie is offline   Reply With Quote
05-04-2008, 04:34 AM   #2 (permalink)
dennis111
Re: Compression and cam timing
What do you consider high compression?
With aluminum heads, a cam with the right timing events, and a small quench (.035-.040 or so) you can get 11:1 to run on 93, or maybe even 91 octane. Much above that and it can be a crap shoot. Iron heads will be a compression point or so less.
Don't expect just any cam with (in your words) "mild" timing to work in this situation. Cam timing events are very, very important, and although there are some off the shelf cams that can work just fine, it often takes an experienced person to give a good cam recommendation.
Dennis
11.52@121.29mph
05-04-2008, 05:58 AM   #3 (permalink)
Mikes66
If you wanted a mild engine, you should not have went with a 347. Those things are monster power makers.
Keep your compression under 11.00 to 1 and you will be able to run on cheaper gas 89 octain, and only loose maybe 20 HP tops at the top end.
If you want to have a monster motor, but have pleasent street mannors, then put a 600 - 650 Vacuum Carb on it. That will keep it on the calmer side then a bigger carb.
Rear gears, and Automatic or Standard will also be big factors.
[SIGPIC][/SIGPIC]
05-04-2008, 07:55 AM   #4 (permalink)
BIGJOE
You CANNOT run 11 to one compression on 89 octane, under ANY circunstances. 10.5 to one with 91 octane will work OK. To get a mild driver camshaft, just spread the lobe centers out to 112 or 114. This will tame it down alot. By the way, flat top pistons on a 347 will give you around 10.5 to one, which is very good.
JOE SHERMAN RACING ENGINES
05-08-2008, 02:15 AM   #5 (permalink)
4Lowie
Thanks guys. I forgot to mention its a Boss style motor. 2V Cleveland heads 12.5 : 1 forged TRW's. I'm looking for ways to lower compression as well. Thick copper head gaskets? Not sure if the closed chamber heads can be opened enough.
05-08-2008, 06:27 AM   #6 (permalink)
JN-Motorsports
Thoughts please.
Thanks, Dave
Dave,
The cam timing can effect the compression. As you probably alread know most cams are ground with +4 advance based on TDC. This is to make the cam more drivable, Idleable.... If you retard the cam to true zero, it can increase the "Static" compression and take some drivability out of it. It's all based on the intake valve closing position and how much intake charge is allowed to excape. It's call the Volume/pressure index and requires a large slide ruler to calculate. Good Luck.
Jeff
J Jackson
JN Motorsports
www.OldGuysGoingFast.com
TAD, S/C, S/G and S/S
JN-Motorsports is offline   Reply With Quote
05-11-2008, 04:57 AM   #7 (permalink)
347LX
When I play with my desk-top dyno and decrease the duratinon on the intake side,making it open later it changes the lobe center from say 110 to 114. This changes shows a good 10-15 hp gain. Does this actualy work in manner or does it make the ramp rates to steep?
64GALAXIE 347 STROKER 12.87@104.6mph
347LX is offline   Reply With Quote
05-11-2008, 01:23 PM   #8 (permalink)
BIGJOE
What do you know about ramp rates ? I have been an engine builder all my life, and I dont know anything about them. The way people talk about camshafts.you would think it is easy for everybody to be a camshaft expert. What I do know about cams, learning from experiance is worth a lot. It is not that you know what works the best, BUT you know what DOES NOT WORK AT ALL. About cams in general, closer lobe centers work best for most engines. As the engine makes more HP per cubic inch, the wider centers, begine to look better. !08 is a very good lobe center for most engines
05-11-2008, 05:14 PM   #9 (permalink)
347LX
I realy dont know a damn thing, I am guessing that if the cam lobe is the same lift but it opens in 8 deg instead of 20 deg it would have to be much steeper and I think that the rate that a cam lobe goes from the base circle to full open is called the "ramp rate". Further more I was not making a statement I was asking a QUESTION!!!! I am not an expert, I'm just some dumbass playing with numbers on a computer program trying to see what makes more power but I am smart enough to know that just because it "looks good on paper" does not mean it will work in the real world/real engine.
05-11-2008, 05:18 PM   #10 (permalink)
347LX
Thanks for your knowledge!
timing chain versus timing gears FALCONERR68 All Ford Techboard 22 05-13-2008 07:37 PM
429 timing - vacuum gauge vs timing light? 69thunderbird All Ford Techboard 1 04-28-2008 04:20 PM
Five-O, HO Compression Wackyman All Ford Techboard 4 04-29-2007 11:55 AM
how to get the correct distributor timing on a 302 engine with a timing light darkstage13 Truck Forum 0 11-26-2006 02:55 AM
HELP GUYS!!! Dynamic Compression VS Static compression...400 Cleveland, Pump Gas! MightyMach All Ford Techboard 26 05-31-2003 12:18 PM
Hays Clutches
