05-15-2008, 03:00 PM   #11 (permalink)
347Fastback
Re: vibration
I haven't tried a 50oz imbalance yet everything has been 28oz. I need to look at the specs from Ford again I believe it said I could use either 28 or 50oz set up.
Ford Racing 347 Short Block Edelbrock performer RPM Heads Air gap intake MSD 6 AL Ignition Demon 650 carb Crane Cam Hedman Headers 2.5" Flowmaster 40 series 3.55 Gears Aubrun Gear Pro series
347Fastback is offline   Reply With Quote
05-15-2008, 05:20 PM   #12 (permalink)
archoplites
Re: vibration
I believe it's one or the other. You can not interchange these parts. The motor shoud have been balanced to either the 28 or 50 setup.
archoplites is offline   Reply With Quote
05-15-2008, 06:23 PM   #13 (permalink)
347Fastback
Re: vibration
Found my paper work on the motor it has to be 28.2 and thats what I have.
05-15-2008, 07:27 PM   #14 (permalink)
Spali32
Re: vibration
Hopefully it's the cam...... Since you want to replace it. But it sounds like your harmonic balancer/or flexplate. Are the engine motor mounts new?? It's definitely a strange vibration.
www.spalisautodetailing.com
05-16-2008, 03:17 AM   #15 (permalink)
347Fastback
Re: vibration
Yes, They are TCP mounts.
05-16-2008, 03:27 AM   #16 (permalink)
Spali32
Re: vibration
So you can eliminate that being the problem...... I have a feeling this forum will help you narrow it down to it's source. It's just a matter of time......
Help Please – Vibration grenouille All Ford Techboard 7 05-30-2006 09:59 PM
vibration 390 C6 rod123 The Garage 4 02-19-2006 02:08 PM
T-5 vibration GeoFordMan All Ford Techboard 3 07-08-2002 10:25 PM
390 FE Vibration mtz2 All Ford Techboard 2 07-01-2002 08:29 PM
Vibration IAPEXL8R All Ford Techboard 4 01-14-2002 12:09 PM
