05-12-2008, 04:21 PM   #1 (permalink)
347Fastback
vibration
I need some help figuring out a surging vibration from 2400 to 3200 RPM. Below 2400 smooth above 3200 smooth no vibration. The motor specs are listed below. I have tried different trans, converter, drive shaft, timing, rear end, tires, carb, the converter is a hughs 3000 stall and a PA C4 trans.
any help would be great.
Thanks Dave
Ford Racing 347 Short Block Edelbrock performer RPM Heads Air gap intake MSD 6 AL Ignition Demon 650 carb Crane Cam Hedman Headers 2.5" Flowmaster 40 series 3.55 Gears Aubrun Gear Pro series
347Fastback is offline   Reply With Quote
05-12-2008, 05:04 PM   #2 (permalink)
mustang42782
Re: vibration
classic wrong flywheel imbalance situation
05-12-2008, 05:16 PM   #3 (permalink)
retyler
Re: vibration
Or damper.
05-12-2008, 05:40 PM   #4 (permalink)
347Fastback
Re: vibration
Originally Posted by retyler View Post
Or damper.
Replaced twice no difference.
05-12-2008, 05:42 PM   #5 (permalink)
347Fastback
Re: vibration
ring gear was replaced also tried the old one and a new one no difference.
05-12-2008, 06:29 PM   #6 (permalink)
Spali32
Re: vibration
Looks like you got yourself a nice combo. Sounds like you have replaced all the items that could cause a vibration. Is this only when the engine is running at idle/up or driving down the road?? I would imagine your ball joints were replaced too. Are your rims balanced and trued. Hit any potholes lately?? Any cracked spark plugs or bad wires. Just trying to see if you might of overlooked anything. Good luck on finding the culprit.
www.spalisautodetailing.com
05-12-2008, 07:21 PM   #7 (permalink)
347Fastback
Re: vibration
Happens while driving or sitting in the driveway at 2400/3200 rpm.
05-13-2008, 06:05 PM   #8 (permalink)
archoplites
Re: vibration
Same symptoms driving or sitting in the driveway. Then you can rule out suspension, driveline, rearend, and wheels.
I'm assuming they are but I will ask... Motor balanced? Flex plate balanced to motor? What imbalance are you running on the 347? Has this vibration always been around with that motor or is it something new?
archoplites is offline   Reply With Quote
05-13-2008, 06:39 PM   #9 (permalink)
mustang42782
Re: vibration
you may have changed those items but did you try both 28 oz and 50 oz? Or just replace them with the same imbalance? OR is it a zero imbalance engine?
05-13-2008, 10:25 PM   #10 (permalink)
steharz
Re: vibration
thats gotta make this abit easier to track down if its vibrating while not moving,my guess to would be in the imbalance
81 aussie ltd-351w,rpm heads,performer rpm airgap intake,10.3 com,angus 1.6 rollers ,1 5/8 long tubes,750 edelbrock,comp xe274h,c4
82 GT mustang 302w-4 speed
55 two door ranchwagon
69 xw falcon wagon
steharz is offline   Reply With Quote
Help Please – Vibration grenouille All Ford Techboard 7 05-30-2006 09:59 PM
vibration 390 C6 rod123 The Garage 4 02-19-2006 02:08 PM
T-5 vibration GeoFordMan All Ford Techboard 3 07-08-2002 10:25 PM
390 FE Vibration mtz2 All Ford Techboard 2 07-01-2002 08:29 PM
Vibration IAPEXL8R All Ford Techboard 4 01-14-2002 12:09 PM
